CSS Diamonds and Hearts
08-05-2022, 04:16 PM
(This post was last modified: 08-05-2022 09:26 PM by The Professor.)
Post: #1
Demonstration of CSS generated animated shapes. Coding is shown in sections that you can C&P into the Analyzer and open.
http://d21c.com/leprofesseur/1/php/newextractor.php http://d21c.com/leprofesseur/feature.html Here are the main code components. This moves the stars and spreads the diamonds a the end http://d21c.com/leprofesseur/css/heart-diamond.js This creates the concentric circles. The circles are layered to produce a ring effect. http://d21c.com/leprofesseur/css/circle.css This creates the hearts http://d21c.com/leprofesseur/css/heart.css This creates the stars. http://d21c.com/leprofesseur/css/star.css Their size can be varied by these lines of code -moz-transform: rotate(35deg) scale(.5); -webkit-transform: rotate(35deg) scale(.5); -ms-transform: rotate(35deg) scale(.5); -o-transform: rotate(35deg) scale(.5); This creates the triangles and rotates them. http://d21c.com/leprofesseur/css/triangle.css By varying start, cycles and iterations independent movement can be created. rd2 is the bottom red triangle and rd is the top one. animation-name: rd2; animation-delay: 5s; animation-duration: 5s; animation-iteration-count: 8; This, as the name implies, zooms the hearts in and out. http://d21c.com/leprofesseur/css/zoom.css By setting the delay to 0 Prof icon appears to materialize out of thin air. The duration time controls the rate of appearance .z-animate-zoom-p{ animation-name: animatezoom; animation-delay: 0s; animation-duration: 204s; animation-iteration-count: 1;} @keyframes animatezoom{from{transform:scale(0)} to{transform:scale(1)}} The resized hearts must be wrapped in a container with the position set at left:0px;top;0px; http://d21c.com/leprofesseur/css/tri-heart-data.css This is the wrap for the red star. It is invisible as it doesn't contain any data #rw{ position:absolute;left:0px;top:0px; } and this is the completed wrap |
08-26-2022, 02:27 PM
Post: #2
RE: CSS Diamonds and Hearts
Nice work. That looks like an awful lot of code to accomplish that. It must take pages and pages of code to make a simple movie, like we used to do with the ming swf codes. There you could draw, position and animate all in one language. I don't know why they retired the Flash application. A lot of games on the web are no longer available, and the HTML5 games that replaced them are not as sophisticated.
LingoLinda
« Next Oldest | Next Newest »
User(s) browsing this thread: 1 Guest(s)
Search
Member List
Calendar
Help
